I started to build a gas tank
Discussion in 'The Garage' started by Supreme70, Mar 21, 2007.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    Well I decided I was going to build my own gas tank/ tool box for the step side, it will hold around 27 gallons give or take Im using the factory sending unit and gas pump.the top portion is 5 inches deep and 9 inches wide and 49 inches long, but I will be putting a little wall between the sending unit and the rest of the tool area.
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    what material are you building it out of?
  3. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    make sure you do a leak test with water.
  4. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    im using 3/16's mild steel, and I will test it with air and soapy water.
  5. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    you can get a special coating too you pour in there and swish around. Used it on a chooper tank we built but can't remember what it is called
  6. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    Is this even legal?
  7. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    I think it is 7 gauge, I put stiffners inside the tank so it be like a pop can.
  8. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    POR 15, STANDARD TANK SEALER!! gas tank coating..
  9. AFUFO
    Apr 26, 2006
    329
    Chesapeake,Virginia
    Dont gastanks that will be used on public roads (will it?) need to be DOT aprooved?
  10. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    dont know, would like to check into gettting it approved from the dot so I wont have any problems.
  11. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    You wont have any problems... No ones gonna know any better to sya anything...
  12. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    I know its stronger then factory and I am using the factory sending unit, factory fill neck and factory overflow out of my old tank, so I dont see any real problems.
  13. 79k20350
    Nov 22, 2004
    7,757
    Ct
    No neither do i... Unless it somehow explodes and kills someone your fine :rolleyes:
  14. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Id be more worried about my passenger saddle tank that leaks if your at to much of an angle, more then a tank I built myself
    Ive also come to notice in the last few years the DOT have their head stuck far up somewhere it shouldnt be most days. This is in Iowa anyway.
  15. AFUFO
    Apr 26, 2006
    329
    Chesapeake,Virginia
    I say because, its "unlawfull" to put gasoline in non-gasloine containers.. so i would assume the same would apply for automotive gas tanks..
    Just something to check before you fail inspection(would they even inspect that)
  16. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    write "gas" on it then it is a specified gasoline container :D
    no different than the millions of service tanks on the back of farm trucks.
  17. AFUFO
    Apr 26, 2006
    329
    Chesapeake,Virginia
    Aiight well let us know if you have any legal problems with it, thatlast post of mine i wasnt aware there was a second page..
