I still got those wet carpets
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, Nov 15, 2001.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    In the bed of my 79 GMC Jimmy the carpet in the bed near the back gate is getting wet. I noticed that there is some condesation on the inside of the fiber glass top but it would not be enough to generate the extreme amont of moisture on the carpet. The drainage holes in the bed are out but it doesnt seem that they are big enough to let this much water through. There is no rust in the bed. I am stumped. anyone have any ideas.
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. Locked front and back.
  2. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    did tou check the tail gate weather strip?close the gate and look from the inside have someone use a flashlight outside and go along the gate and if you see light bingo!
    1977 k5-blazer 4"softride 3.5 in rear dana 44,12 bolt rear,6 cyl,205 t-case,465 trans
  3. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    that could very well be it. Thanks alot.
  4. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    TAILGATE IS LEAKING, I just went through this with my truck. Get the new outside seal, and make sur eyou have the seals that go on the inspection cover, then for added security, I acually ciliconed the bottom part of the inspection cover, I know it'll be hard to take off, but everything inside of mine is new.
    Ben 87 Jimmy
  5. BASSMAN
    BASSMAN Registered Member
    Jan 16, 2001
    37
    S.E. VA.
    HAVE TO AGREE WITH EVERYONE ELSE A LEAKING TAILGATE, BEEN THERE DONE THAT. THE CONDENSATION IS FROM THE WET CARPET NOT THE OTHER WAY AROUND
  6. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    well i could have bad news for you. If you live up north, or a place with salt it could be caused from corrosion. The bed support underneat can trap mud, salt, etc between it and the ridges in the bed. Then the bed will rust from the underside to the inside. So pull up the carpet, padding, and the insulation and see if you have holes. I sure did, i could fit my fist through them on both sides behind the wheels. I hope this isn't your problem. - Doug
    Doug Krebs
  7. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    I would put a silicone bead on the bottom but i would be worried about water getting trapped inside the tailegate. What do you guys mean by inspection gate. I pulled up the carpet and there is no rust. I live in the bay area so our weather is pretty moderate.
