I sure hope a shackle flip is worth it..
Discussion in 'The Garage' started by twoslo4five0, Apr 21, 2007.
  1. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,615
    71
    Living in a dump, VA
    Just got done working and im freaking exhausted...got 4 of the rivets ground down and the pass side shackle hanger off...man im beat...also got the old blocks out and one of the zero rates instaled and the u bolt and everything put back togher...i sure hope all this work is worth it!!!
  2. 1982blazer
    1982blazer 1/2 ton status
    May 11, 2006
    313
    Tyler Texas
    I am doing the same thing you are and removing the rivets is tuely a pain in the a$$.
  3. twoslo4five0
    Oct 5, 2006
    6,615
    71
    yeah how are you removing yours???is a grinder the best way???
  4. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    hot wrench and then air chissle when hot each one to pop the rest out.
    and you will love the way the flip rides when done. much softer . it fells funny at first and over 45* angles . like if you dont go stright in to a parking lot thats raised off the main street.
  5. twoslo4five0
    Oct 5, 2006
    6,615
    71
    i might be dumb but what is a hot wrench..i tried the air chisel today but no use....
  6. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Are you working on the burb? If so, they are a pain, but just wait till you get to the driver side,lol. I use a torch to trim the head of the rivet off, then pry the bracket off with a large prybar, then grind the rivet flush with frame and beat it out with a hammer and punch or air chisel.
    Just keep at it, and before you know it, you'll be done.
    Jimbo
  7. twoslo4five0
    Oct 5, 2006
    6,615
    71
    yes i am...i have to drop the tank tomm i think not gonna be fun the straps are all rusty...the only torch i have is one of the little sodering propane torches...
  8. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    really.. I had the side 4 rivets and 2 on the inside of the frame off in 30 mins.. redrilled my holes.... all bolted back on one side in 1.5hrs...
    however yer doin a flip... good luck.. wish I was doing a flip... im just moving my hangers back.. :doah:
  9. twoslo4five0
    Oct 5, 2006
    6,615
    71
    you also have to remember you didnt have a bed...not complaning at all but its a lil harder climing undernieth and positiong everything right and not having any room...
  10. 1982blazer
    May 11, 2006
    313
    Tyler Texas
    All i have is a grinder, a drill , a bfh, and a punch. I have been grinding the heads off the rivets, i tried just punching them out after i grinded the heads off but that wouldnt work. So i have been drilling them out some then punching them through. I got the drivers side hanger off now, but one of the rivets on the inside of the frame rail is stuck and wont move and i have tried everything i guess i will just drill it out.
    Edit: I highly doubt grinding them off is the best way but it is the only way i have to remove them.
  11. RootBreaker
    Nov 29, 2001
    5,118
    173
    ya know what dude.. yer right.. with the bed off.. I used my bfh and could swing that puppy...
    also used a 5' crowbar!!
  12. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    You guys are going about it all wrong. Just use a good quality cold chisle and knock them sum b!tches off with a BFH. It took maybe 15 minutes to remove my old shackle mounts this way.......Oh and wear protective clothing and eye wear..........
  13. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    Never tried it Corey's way, but the grinder worked well for me. Good things is, I won't ever have to grind those rivets again.
  14. twoslo4five0
    Oct 5, 2006
    6,615
    71
    i would love to but i dont have enough room under the burb 4 that...
  15. Corey 78K5
    13,055
    Humboldt County, CA
    Hell I did it under my Blazer. Give it a try, the heads will pop off usually with one swing........
  16. twoslo4five0
    Oct 5, 2006
    6,615
    71
    ill give it a shot tomm...gotta find my chisel though..
  17. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Watcha you talking about Willis??? First I've heard of doing it this way. I've had my flip in the garage for a few months now and been puttling off the job. I've been dreading the rivits.
    Please give this short bus student some insight.
  18. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    That's how I did mine !!!!!
    Just make sure the chisel is sharp.
  19. Corey 78K5
    13,055
    Humboldt County, CA
    Take a good cold chisle (US made not China) and a 3-5 Lbs hammer and knock them off. Its pretty easy........
  20. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Thanks - I'll give it a shot.
