I think he's crazy
Discussion in 'The Garage' started by neverendingproject, Apr 1, 2007.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    If *think* the Sterling has 12 bolts that retain the ring gear to the carrier.
    Tom
  3. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Well then that would make more sense. I started reading and he started say 14 10.25 and then 12. It threw me for a loop.
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    It is for a 10.25"/10.5" Ford Sterling rear axle. The Sterling axle has 12 cover bolts and he is mistakingly calling the axle something it isn't.
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    That's not for a 10.25"/10.5" Ford. The Ford one is a full case and looks like this:
    EDIT: whatever it is the guy is selling, the spline count would be helpful. There is a drop-in style like that for a D70 though.
  6. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Look at your pic, you must take the two halves apart and the detroit goes inside just like a 14ff.
  7. u2slow
    May 9, 2001
    2,217
    BC Canada
    That's a fine theory - but the stock Ford case is a 1-piece (doesn't split apart) unless its the newer split case 3-spider posi.
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If the detroit case comes apart would you not be able to buy the internal "detroit" itself if it ever did break? Maybe that is what he is selling.
    It could be for a Dana 70 as was mentioned as they too have a split case like a 14FF.
    Ira
  9. u2slow
    May 9, 2001
    2,217
    BC Canada
    Maybe - but you can buy a complete new Detroit for the 10.25" for $599 advertised online. :confused:
    The seller should post the part number to avoid confusion. How do you confirm the application beforehand with the garbage info provided?
    Perhaps he's flip-flopping between diff cover bolts and carrier bolts. After all, and 14-bolt has 12 ring gear bolts. ;)
  10. sandawgk5
    Oct 28, 2003
    6,881
    I am not disputing the guy is ****ed up, just that to say it is not for a ford with the info given I dont think is possible.
    His price is outrageous I would agree.
    Ira
  11. u2slow
    May 9, 2001
    2,217
    BC Canada
    No worries... I just get worked up over eBay ads that are incomplete, have omitted critical information, or are otherwise misleading. :crazy:
  12. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Question: When does the 10.25 sterling become 10.5?
  13. sandawgk5
    Oct 28, 2003
    6,881
    Did it have 2 different size ring gears but the case internals are the same?
    I dunno there is no telling with F*rd.:D
    Ira
  14. u2slow
    May 9, 2001
    2,217
    BC Canada
    Went to 10.5" for the Superduty (99+). The carrier is interchangeable.
  15. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    This pic is a 2 piece case. The 8 bolts hold the 2 pieces together. If the detroit in question is a part number 225SL-56A then it is for a 10.25"/10.5" sterling.
  16. u2slow
    May 9, 2001
    2,217
    BC Canada
    Of course its a 2-piece. It comes like that out of the Tractech box. I'd know - I bought it and unboxed it. :D
    The stock 10.25" diff cases (open or posi) are all 1-piece units.
