I think i have a cracked block
Discussion in 'The Garage' started by k5freak44, Sep 9, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Alright heres my symptoms,
    smoke on startup when cool
    sweet smelling exhaust
    very low coolant (i filled it back up)
    nasty gunk all over the block by the rear pass sparkplug
    not alot but a tiny bit of water in the pass tailpipe
    engine stumbles until its warm
    What do you think?
    Thanks Again
    Jonathan
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    could be cracked head, cracked block, or most likely a blown head gasket.
    the oil on the head by the plug is most likely from a leaky vavle cover gasket.
  3. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    i see the oil from the valve cover gaskets but this stuff i see is isolated around one sparkplug and i dosent start at the valve covers.
    anyone esle?
    thanks
  4. blazerguy 90
    blazerguy 90 1/2 ton status
    Nov 12, 2004
    126
    EL Sobrante, CA
    I would guess that you probably have a blown head gasket.
  5. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Put a pressure test on it...Go to Autozone, Advance, whatever and rent a pressure tester.
    Cracked block is an awfully serious problem to be jumping to the conclusion of.... :confused:
  6. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,011
    841
    Pinckney, MI
    like he said, test your compression. Is it only on one side or is it both??
  7. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    both sides smoke, one side has water in the pipe and it is the same side with all the gunk around the sparkplug
    thanks guys
  8. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    is there water in the oil?
  9. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    nope no water in the oil
  10. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    is the water there all the time or upon start up..it is normal for some to be there if it hasnt reached proper temps..byproduct of burning gas..
  11. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    could it be bad threads on the plug or in the block? cracked or broken plug?
  12. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    I dont know when the water is there but its not very much. Everything is happening on my passenger side, and i have true duals so i am only seeing water and smoke on one side.
    I ONLY get smoke on startup tho, out of the pass. tailpipe
    -jon
  13. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    Maby, ill pull the plug tomarro.
