i think i might have a problem with my front high angle shaft
Discussion in 'The Garage' started by yunit, Oct 21, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I only have about 3" tops of open spline when on level ground. I looked at Steve Fox's front driveshaft and he has at least 6".
    Man this fawking truck is going to give me gray fawking hair. Look's like I am going to have to pull the shaft and get it shortened...fawkin [darn].
    /forums/images/graemlins/angryfire.gif
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Could be worse. You could be like me and not have a fancy front shaft to shorten /forums/images/graemlins/tongue.gif And I am still trying to find a way to get that tailgate from jimmy88. I may just break down and drive out, swing past pappys and pick up my tires while I'm out that way /forums/images/graemlins/thumb.gif
  3. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Dood that sucks.
    Have you cycled your front springs yet? You did get new ones didn't you?
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    You have 3" of compression available? That's more than enough, my last shaft only had 2" or so. Do the math, I doubt that the shackles will even allow the axle to travel that far back.
  5. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    The truck might be running this weekend, so I will try to flex it out and see if the t-cases rip off of the tranny. /forums/images/graemlins/tongue.gif
  6. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Steve fox might have gotten a long spline version as where it sounds like you have a normal one. Just an thought.
  7. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Okay so it's really ugly and hard to see but - if you measure along the arc of the spring to the face of the yoke, remember it (the blue line); and then measure that same distance directly from the spring eye (red line); and mark it. Then measure from the face of the t-case flange to the mark (yellow line) and the length from the flange to the yoke (purple). Then take the difference between the purple and yellow distances you have the total possible amount that the driveshaft should ever have to compress right? /forums/images/graemlins/thinking.gif Hopefully less than 3".
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    You're fine, as Evan said. Leaf springs, typical shackles, you would probably be into the frame/exhaust/oil pan before the d-shaft would bottom. My .02
  9. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    As the others said, you will be fine.
    Just think, if you go with coils and 4 link, you will only need about 1/4" of travel if done right! /forums/images/graemlins/thumb.gif
