I think I'm a dumbass, 14 ff carrier won't come out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76K5, Dec 18, 2002.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    I think I\'m a dumbass, 14 ff carrier won\'t come out
    Actually I know I'm a dumbass. I think I finally realized the problem why I couldn't get the carrier out. After taking the two main caps off I thought all I had to do was take off those bent metal straps that are held on by the small bolt on each side. I thought these were the adjusters, so I'm guessing I need to rotate the pieces with the small holes in them to get loose the carrier. That sucks, I bet I probably damaged the adjusters with all of the beating I did to get the carrier out while they were still tight. I feel like an idiot!!! Anyway, just wanted to vent. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: I think I\'m a dumbass, 14 ff carrier won\'t come out
    Yes, the adjustable collars need to be loosened. They control both backlash and carrier bearing preload.
    Count exactly how much turns you make.
    -- Mike
  3. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    just loosen the collars on each side of the carrier. Make a mark then count how many full turn and write down for each side so when putting back together you have the same backlash/ preload.
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    well did you take the axles out, that sure as hell would keep that sunufabitch in there. good luck on that. /forums/images/graemlins/thumb.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Be careful as you loosen the adjusters. Once they're loose, the carrier will literally fall out of the housing! /forums/images/graemlins/shocked.gif That sucker is plenty heavy enough to smash a couple of fingers really flat. /forums/images/graemlins/frown.gif
