i think my 700r4 is toast!!! HELP!! first 700r4 experience update.. fixed!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Jul 6, 2003.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    its fixed i picked it up today.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: i think my 700r4 is toast!!! HELP!! first 700r4 experience
    hows the fluid level? hows the TV adjustment? little things you should check before jumping ahead of yourself... do a search, somewhere theres a post about adjusting your TV cable..
  3. muddysub
    Jun 23, 2001
    10,451
    489
    ok ill check the fluid level wen it cools down some and i dont kno a damn thing about TV cables. i'll do some searchin. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
  4. Confedneck
    Nov 1, 2002
    5,236
    dont check the fluid level cold, start it up and let it idle in park or neutral and check the level..good luck..
  5. muddysub
    Jun 23, 2001
    10,451
    489
    ok thanks
  6. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Check the govenor gear. My 700 went south earlier this week and that was one of the things that went. All I had was first gear, my revs would get to about 2500, then jump trying to get into 2nd then stay in 1st.
    Looks like its toast.
  7. muddysub
    Jun 23, 2001
    10,451
    489
    wheres the governor gear? /forums/images/graemlins/confused.gif
  8. Bullet
    Mar 14, 2001
    1,222
    Abilene, Texas
    its the lil external round cap on the driver side of the tranny, up top, near the rear. You'll need to pry it off IIRC
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    It's either your servo(governor gear) or it's burning up the clutches one gear at a time. I've never heard of anyone just losing reverse and second before though, usually OD goes then 3rd,2nd,1st then ya use reverse to drive to the tranny shop were you get to spend $1000 on a new 700. /forums/images/graemlins/cool.gif
    85'K5 14bolt,10bolt 3/4ton, 9" lift 35"boggers 16.5x14 welds,big horse 406SB/700r4 w/corvette comp. /forums/images/graemlins/k5.gif
  10. muddysub
    Jun 23, 2001
    10,451
    489
    [/ QUOTE ] ok wat am i looking for wen i remove this thing?
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    About time that 3/4 ton Suburban gets a REAL 3/4 ton tranny and transfer case. I'd search for a TH 400/205 if you insist that it be an automatic.
    I had a 700R4 once. And only once!!!
  12. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    I'm pretty sure his Suburban does have a 400 in it. I think he is talking about another truck. I don't see everyones hatred for 700r4's. My truck used to tow a skidloader and trailor daily and never has had a problem with the tranny. I guess I don't treat my truck rough enough.
    Jon
  13. muddysub
    Jun 23, 2001
    10,451
    489
    yea my sub has always had a th400 in it. we're talkin about my little 1/2 ton commuter truck.
  14. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Dont know if this is the problem, but to adjust the TV cable go here: TV Cable Adjustment. It has some good information about adjusting the TV Cable, and what it does.
    -Harrison
  15. muddysub
    Jun 23, 2001
    10,451
    489
    [/ QUOTE ] good very informative and simple, i am afterall a UTI student so pictures help! /forums/images/graemlins/thumb.gif
  16. njonl
    njonl 1/2 ton status
    Jun 30, 2003
    128
    Northern CA
    My tranny is kind of doing the same thing. I let a friend borrow it to go camping and he calls me and asks if my tranny has ever slipped before and that the fluid level was really low. It has never given me any problems before. Now, I have no third gear or overdrive. It shifts really hard when going from first to second and then slips really bad in third and eventually downshifts back to second. Any idea's ? Any help is appreciated. Thanks.
  17. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    ok forget the tb400 and 350 swap! The thing that guys don't understand is that you have to rebuild the early 700's RIGHT! The corvette components have to be used to make a strong reliable 700. Any idiot that says he's blown a half a dozen 700's either doesn't know how to rebuild it right or replaced it with some 100,000 mile worn out pick-n-pull 700. If built right a 700 can handle 500hp,now how many of us have more than 500hp,I have close to that in my 85'K5 and I run a professionally built PERFORMANCE 700r4.tb400's are very heavy, no overdrive, high ratio first gear, and the adapter that is needed is $450 from advance adapters. /forums/images/graemlins/cool.gif
    85K5 3/4ton 9" lift 35"boggers 16.5x14 welds, big horse 406SBC/700r4 corvette components. /forums/images/graemlins/k5.gif
  18. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Yeah, I'm kicking myself for replacing my 700 with a 400. It's neat to know it's bulletproof and all that, but life isn't so good as I cruise down the interstate at 3100 RPM.
  19. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    HA HA HA!!! Once you've blown your 700R4 you enter a long journey into an empty wallet!!! They are not designed for high-horse applications, if they were they would have been installed behind 454s when they first came on line in 1982. Proper built or not, they WILL blow again, it's just a matter of time!!! Go ahead, keep draining your wallet for 700s!!! HA HA HA!!!!
  20. 87BrnRsd
    Apr 21, 2003
    2,457
    No problem. It helped me too. /forums/images/graemlins/thumb.gif
    -Harrison
