I think my axle relocated itself
Discussion in 'The Garage' started by Paxx, Nov 30, 2003.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    I went out the other night and wheeled Brown Betty HARD. I had her flexed right out with the rear tire hanging about 2 and a half feet in the air at one point. (Found out I need to trim real bad /forums/images/graemlins/grin.gif) Anyways, today I was looking at Betty and I noticed that the tire seemed really close to the back of the fender. I took a look and I think the axle slid back about an inch on the springs. /forums/images/graemlins/eek.gif Has this happened to anyone before? Do I just loosen the u-bolts and move it back then re-tighten? How do I prevent this from happening again?
    Thnx ~Max
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    center pin broke sounds like. Need to pull the spring apart and put in a new spring back, maybe new ubolts then retighten. Should be fine.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yea, if your axle moved and the u-bolts are still "tight" then you broke a center pin /forums/images/graemlins/eek.gif. Napa sells new pins or you can use 3/8" Grade 8 allen head bolts like I did. /forums/images/graemlins/thumb.gif
  4. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    carnage!! yeah its the pin. they are real easy to replace. impact tools make it even easyer. good luck!!
  5. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    Hey Max, yup sounds like you center pin snapped. Give me a call and you can bring it up to the track and we caan fix it there. easy fix. i might even have a center pin lyin around here somewhere. Talk to you soon man.
