I think my steering box is crapping out...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Feb 1, 2001.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    It has been making "popping" noise's for the past couple months, but in the past day's it has been getting LOUDER ! What should I do?
    <font color=blue> Taxes are Stealing</font color=blue>
    <P ID="edit"><FONT SIZE=-1>Edited by useyourblinker on 02/01/01 04:42 PM (server time).</FONT></P>
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Check your frame for cracks aruond the bolt holes. Mine did the same and the frame was just starting to crack. Installed Stering brace no more probs.
  3. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    Your problem sounds similar to what I had... Mine was making a poping noise when I would turn from side to side..
    so I had a friend turn the wheel while I was watching and it turned out that my leaf spring was loose... I tightened it up and away the noise went.... good luck
    BlazerBoy
    http://generalblueballs.coloradok5.com
  4. UseYourBlinker
    Jun 7, 2000
    11,117
    I had my bro turn the wheel so I could look to see where the noise is coming from. It's coming from the box. I check the fluid level in the steering pump and it's O.K. It's not the springs, and there is no cracks on the frame that I can see.. hmmmmm anything else?
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    These guys are right on track. Check for cracks, leaf springs or even loose bolts on the gear box.
    creepin' and crawlin'
    Jim
  6. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Mine did that... I replaced the steering box outta a wrecked truck a buddie had.. went away... My steering wheel mada a wierd thing whe nit turned... Like the power steering was kickin in and out... All better now...
    Um... yes officer I know it's too big...
  7. UseYourBlinker
    Jun 7, 2000
    11,117
    Well if I have to replace the steering box. What are some good company's that might them? I have seen AGR but they are kinda $$$
  8. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    Hey Aaron, did your steering seem like you were out of fluid but you were'nt? The wheels only turn if you let the truck move a little first? I was thinking my pump was dead, but you say it was the steering box itself?
    Rene
  9. 78k5
    78k5 1/2 ton status
    Apr 25, 2000
    173
    Big Island, Va.
    Autozone has them for $160.00 here I am getting one Tuesday.
