I thought muddin' was supposed to be fun...
Discussion in 'The Garage' started by mountainexplorer, Mar 23, 2007.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Today it was a huge pain in the rear.
    Step 1: Drive out back to retrieve a hood and fender.
    Step 2: Drive back down to field to pull other parts and load up axles and leave.
    It took me about 3 hours to get to step 2. Going back down my road idling along, the flatbed started to drag the rear differential so I backed up to get a run at it. When I backed up, the rear end high centered and it wouldn't move forward or back.
    If only I could add the movement and flowing water sound effect to this image.
    I call Greg, who comes up and gives me a tug with his Jeep, which is all I needed to get free of that one spot. Then he got stuck. So I hook back up and pull him back. With the wheelbase and narrower track of the Cherokee he is able to get out of the ruts and get out. My highway tires and regular wheelbase/track kept me in the ruts, so I just go for it.
    I am able to rock it back and forth and make progress, until I suddenly halt abruptly. High centered again. Greg tried tugging on me again. I see the Jeep back up and lunge forward, but I don't feel a thing. Only thing I saw was the strap break after several tries. I also discover I'm able to hit 4th gear and reach 50mph on the speedometer. My tires were pretty much in the air (above ground).
    We go down and get my Stepside, to use the winch. We drive up in the Stepside... I go around the flatbed and drive out back to turn around (in an attempt to winch the flatbed backwards to free it).
    The Stepside runs out of gas once we get out back.
    We walk back down and I find about a gallon of old gas that I saved from a parts truck I flipped up side down a month earlier (and had saved the gas into a bucket as it ran out of the tank). I have no extra money to buy new gas cause I have $6 left to my name right now until I sell something.
    I go add the gas, start the Stepside, turn around and we hook up the winch. Greg puts the flatbed in reverse as I winch it backwards. This is a 9000lb Warn winch, of which has done well every time I have used it in the past. It won't even budge the Flatbed. I let the motor run for a bit to account for the battery drain, but have to shut it down cause my gallon of gas won't last long.
    I decide to do what you aren't supposed to do and pull backwards with the Stepside using the winch cable. I go to start the Stepside. Dead. Both batteries are drained dead from the amount of energy the winch was using trying to pull the flatbed, even with me keeping the engine running/charging the whole time.
    Greg walks down and get his Jeep, comes up and jump starts the Stepside, I try backing up and all 4 of my Boggers just spin as well as the tires on the flatbed. No movement. Finally I just start jerkeing on the cable a little harder each time until it finally pulls the flatbed back. Then after a few tries, we get the flatbed driven out and down to the field.
    By now it's the time I'm supposed to be leaving and I'm just starting Step 2 according to my plan. (notice my Cherry Picker doesn't roll too well either). The flatbed barely made it across this section of the front yard without getting stuck. So much for my grass this year.
    I thought mudding was supposed to be fun... but in my life, it's just a reality be it a fun day or work day.
  2. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Wow....it's been a long time since I drove a muddy road in tires like that. Nice pics. Brings back memories of when I got my K30 as a bone stock utility company vehicle. I also recall minimal progress on similar roads.:o
  3. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Mudding is fun, when you aren't running slicks!
  4. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    What? That sounded like fun to me! j/k. I've had days like that when you make a little progress just to have another snag puts you further behind than you were at first.
  5. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Ya I would consider that a typical fun day. Small tasks become bigger tasks all the time. DAM MURPHY'S LAW. lol. I know you were trying to do something so its not so fun. Man once again I love your place. You have so many cool rigs sitting around.
  6. runamok151
    runamok151 1 ton status Premium Member
    Oct 24, 2005
    12,540
    1,433
    the armpit of the east coast, 08046
    beats sitting in an office
  7. AKbigsub
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    Where in Spokane is that?
  8. mountainexplorer
    Nov 14, 2001
    4,903
    1 mile NW of Ione, Wa.
  9. AKbigsub
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    I was up that way once with my scout troop looking at some big horn sheep. I think we went as far as Metaline Falls. It is sure a pretty part of the country there. Are the forest service/logging roads still accessable or has the fed closed them down?
  10. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    aslong as you get your rig stuck on your own property you can say screw it and walk inside, watch tv and fix it later
  11. cabledawg
    cabledawg Secret Squirrel Premium Member
    Sep 12, 2006
    2,647
    Highway to Hell
    mountainexplorer...you know where the Columbia river is? I got my s-10 buried to the doors about ten years ago when the river was down. Probably still be there if some guy didnt come down and help me shovel the truck out.
  12. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Kinda sounds like a typical day...:doah:
  13. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Can I come over and play at your house? Puh-weeeeze! :D
  14. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    that is the norm. in indiana with sicks. haha glad you got it out:wink1:
