I thought my trans pan gasket was leaking... but.
Discussion in 'The Garage' started by Scott A, Jul 25, 2006.
  1. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    My TH350 has been leaking so I snugged down the pan bolts. From closer inspection I can see that my TV cable is leaking ATF??? I thought it was leaking from where it is bolted to the trans, but it's actually leaking from the cable??
  2. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    I know this does not help but I don't think t350 have TV cables they have kick down cables
  3. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    Oh yeah, your right. Thanks.
    Anyhow, looks like I need a new cable.
  4. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    cable broken??
    Unless its broken,you dont need a cable..there is an "O" ring under where it slides in the tranny case..that 10mm bolt holds the cable in..in most cases you can take the cable off and put it back without pulling the pan off the tranny..I made a gasket from a peice of an old inner tube for one stubborn leaky cable I had in one of my TH350's..that stopped the leak after putting a new "O" ring in didn't help..:crazy:
  5. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    ahhh, i had that crap leak too, except mine was due to the little bolt hole being stripped...
    i fixed it by installing a th400 :)
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Hum, my UTI edumacated tech friend always called it a TV cable. That was b4 he went to UTI, but I can't recall him saying any different later.
