I used the search but...86K5w/35"and6"susp lift good or bad?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by VitaminK5, Feb 12, 2003.
  1. VitaminK5
    VitaminK5 Registered Member
    Feb 11, 2003
    6
    NJTPK Exit 11, NJ
    I used the search but...86K5w/35\"and6\"susp lift good or bad?
    I was looking into a 6" skyjacker lift to fit thirty-five inch tires on an 86 K5. What oddball part would I be ordering extra? The kit description showed the shims for realigning the driveshaft but what about steering components, brake lines, etcetera? Electrical issues with harnesses? Two shops responded so far to do it. I want to make sure nothing is left out like recallibrating the speedo.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: I used the search but...86K5w/35\"and6\"susp lift good or bad?
    A 6" suspension lift won't need to have anything done to the wiring, shifters, or steering shaft - those are all things you would have to worry about with a body lift.
    Yes, you should run extended brake lines. ProComp and SkyJacker both sell brake lines for between $80 and $100.
    Rear driveshaft WILL need to be lengthened. Front driveshaft MAY need to be lengthened, and really OUGHT to be if isn't required.
    Recalibrating speedo - you got me there, I wish my speedo would just work and then I'd worry about it reading right.
    -- Mike
  3. VitaminK5
    Feb 11, 2003
    6
    NJTPK Exit 11, NJ
    Thanks, I just heard from a shop to get her done. I asked for the skyjacker in the email. I'll look up the brake lines and driveshaft. Links off this site I hope.
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    There's a gear in the transfer case that runs the speedo.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] When I installed my 6" lift (Superlift front springs) my front driveshaft was too short to hook up. I was able to drive to the driveshaft shop on the rear shaft, but I took it very easy, one good bump would have popped it apart.
  6. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    look at my link i got the 6" with 35"TSL and love it hehe /forums/images/graemlins/grin.gif gonna go bigger with the tires though
  7. mudober
    mudober Registered Member
    Feb 19, 2002
    23
    I chose a 4" susp. &amp; 2" body I run 14-35-15 gumbos with no problems.
