I wana lose my spring plates...
Discussion in 'The Garage' started by BigMac, Aug 16, 2002.
  1. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    I just got off the phone with 4 wheel parts wholesaler...they weren't not able to help me...
    What I want to do is swap the orientation of the u bolts hanging a 14 ff on my springs. IE, I want the U to the bottom.
    Where can I get the plates? I dont need the u bolts... I plan to have them made.
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    go to your local wrecking yard.
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    OFFROADDESIGN.COM
  4. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
  5. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    I found mine at the jyard for a couple bucks(in good shape I might add).
  6. BigMac
    May 27, 2002
    397
    Fremont, CA
    You guys are using stock plates outa the junk yard? Doesn't seem like that would work out so good. I cannot see how a stock one would work over the spring plates....trying to imagine /forums/images/icons/confused.gif
    Anyway, I REALLY like the ORD plates! I guess I'll get those and the shackle flip and maybe save some shipping.
    Thanks!
  7. Grim-Reaper
    7,385
    Atlanta
    Let me get this right....you want the bolt end of the u-bolt pointed towarsd the ground? Uhhhhh Why? Jeeps came that way and people did every thing they coud to get them pointed up like a 14 came. The hang on rocks, bash up the threads so you have to cut them off if you even need to take the axle loose.
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    spring plates are your friends... trust us...
    J
  9. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    Get 3/4 ton spring plates, they point the threads up. Some one ton setups put the threads down.
    Marc
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you want the threads to point down, like the K30's, I have some brand new plates that will work for what you are wanting to do.
    I ordered these for a K30 mock up when I didn't have the axles yet. I even got the little metal pieces that sit on top of the springs to hold the u-bolts in place, too.
    All 4 pieces you need to use the square bend u-bolts for $40 shipped to your door.
  11. BigMac
    May 27, 2002
    397
    Fremont, CA
    noooo I want the closed end of the u down. like a 12 bolt
  12. BigMac
    May 27, 2002
    397
    Fremont, CA
    ok now I think I get it. I can get the spring plates from a 3/4 ton axle and get the threads outa the dirt. Cool, Off to the junkyard. I hadn't seen 3/4 ton plates. I'd only seen one ton. Thats what I meant when I couldnt see how the stock plate would work on top of the spring... I was thinking one ton not 3/4.
    I'm pretty sure I can pick up some plates when I go fing my new gas tank.
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Oh, you mean you want the threads to point "up".
  14. BigMac
    May 27, 2002
    397
    Fremont, CA
    yup..... found a pair of 3/4 ton plates today.
    Came for free with me new blazer gas tank and cross member.
    I'm really beginnin to like those junk yars out in the valley.
  15. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    where'd ya go? I need to find some new spots for parts.
  16. BigMac
    May 27, 2002
    397
    Fremont, CA
    I went to a little hole in the wall in Modesto. The guy I went with is budies with the guys runnin the place. We got to use their torch to get the cross member out.
    Treasures!
