I want 5.13's but i hear the pinion gets weaker.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silver84k5, Feb 23, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    I want 5.13\'s but i hear the pinion gets weaker.....
    I know some of you guys are running 5.13's, i want to get 5.13's with 42"s, but some one tells me the pinion gets smaller and weaker, can anyone gimme some feedback, Thx,
    If you dont make it the first time, Drink another beer, and press a little harder on the gas
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Re: I want 5.13\'s but i hear the pinion gets weaker.....
    I wouldn't worry too much on a 14 or a 60, and IMO a 10 or a 44 is doomed w/42s anyway.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    a 10 is doomed with pretty much any tire,
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    What size axles are you talking about?
    I have no personal experience here but, the number I hear for D60 pinions becoming a problem are when you cross the upper 5s or into the 6s. 5.13s I've never heard people complain about. The C14 can't go any deeper anyway and they hold up fine with the 5.13s from everything I've heard or seen. I'll likely end up with 5.13s before it is over with.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Thx, glad to hear there, im talking 14ff....... and a d60 (hopefully someday soon)
  6. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Yes. You should be fine with 5.13s and 14/D60. I wouldn't go taller than 4.56 in a D44 or 10.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  7. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    is pinion strength really that big of a concern? I know those are some big tires and some low gears which is hard as hell on parts but I dont think ive ever seen a broken pinion shaft or gear. If I have- it was due to something else breaking or causing it to break like a ring gear bolt coming loose, etc
    mike
  8. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i have been thinking that same thing Mike, ive never heard of something like that either
