I want my truck LIFTED!
Discussion in 'The Garage' started by JimmyJuneau, Feb 15, 2003.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok I have owned my GMC Jimmy for close to four years now and its still at stock height. I have the blocks to do the rear but cant find the springs to do the front. And Im not that confident in lifting the truck myself. The shops around here want to charge me an arm and a leg. Any suggestions on where to find the springs at a decent price and how to lift the sucker!
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Installing the lift isn't hard. I'm sure some members will be contacting you about springs. How high do you want to lift it ???
  3. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    Depends on how high you want it. If you keep it at 4 inches or less, you shouldn't have to do much more than change shocks, steering arm, and springs. It's not hard to do if you got the jacks and stands. Watch the for sale colum, I see springs for sale on there all the time. Anything over 4 inches and you will probably have to change brake lines, possibly shim the tranny, etc... What type of tires do you want to fit?
  4. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Well Im thinking about 35 inch tires. If Used that size of tire would I have to trim the fenders for the rear tires? I dont mind triming up front abit cause my right fender is dented up. So if I only do a 4 inch lift I dont have to change the brake lines or steering arm?
  5. ibrakeformud
    ibrakeformud 1/2 ton status
    Jan 8, 2002
    118
    vancouver wa
    im in the middle of lifting my truck 4 inches and i have to change my brake lines steering arm and shocks
  6. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Join the Nor Cal Big Dawgs and I'm sure someone close to you will be willing to help you out. I don't know how to do jack as in this stuff, but if you need a welder I have one you can use, and am willing to help in other ways if I can... /forums/images/graemlins/thumb.gif
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I lifted 4" and did steering arm and hadta do the brake lines.
  8. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    well i know with my 6 inch i had to get a new steering arm, but i still use stock brake lines its fine for now, but if you are going to do any flexing yes get longer ones, i just ran mine around the frame for now, and i have just as much after lift as i did before lift, installing them arent hard, but if you check out rough country they have a 4 inch lift with the arm and springs and blocks completer lift for like 300 bucks, that would be the best way to go, that way you know you have everything, as far as installing it, thats easy aslong as isnt not rusted like mine was, but i wont go there on ya, lift isnt bad though for sfa , hardest part is getting stock arm off, and the trick is a BFH and beat it like you stole it, after that its cravy /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  9. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    On my 72, i had to do the steering arm and brake lines. The steering arm will come off really hard which is a pain, but i really recommend changing it. I used 4" trailmaster springs which lifted it about 6.5 inches but settled to 5.5, really rough until i got the V8 and front bumper on.
  10. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
  11. RatMan
    RatMan 1/2 ton status
    Jul 27, 2002
    270
    Marietta, Georgia
    it's a bit of a drive from northern cali to alaska. way to be a team player and volunteer though! /forums/images/graemlins/thumb.gif
