I want to do a swap on my 76 what needs to be done?
Discussion in 'The Garage' started by speed_deed, May 31, 2003.
  1. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    I want to put the TH700R4 in place of my SM465 I want to keep the NP205 in it. I know I am going to have to switch the column the gauages and ofcoarse the tranny itself, do I need an adapter to keep my NP205?
  2. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    Anybody?
  3. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif TTT /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif I know somebody knows something! /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
  4. Grim-Reaper
    7,385
    Atlanta
    It's a bolt in. you will need a spacer to bolt the 205 to the 700. www.offroaddesign.com can proably help you with that or Advanced adaptors. Then your going to have to adjust your drive shaft lengths. You will also need a contol set up to run the OD and lock up converter on the 700. I think Painless wiring has that.
    Now straighten out your panties /forums/images/graemlins/rotfl.gif
  5. Grim-Reaper
    7,385
    Atlanta
    Ohh yah your going to need a new 28 spline input shaft for the 205 since you have a 465. That or find a TH350 205.
  6. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    27 spline input for the 205, present is 10 spline.
  7. Grim-Reaper
    7,385
    Atlanta
    Opps...mixing up my input shafts with my axle shafts....Yeah 27! LOL.
    Honestly the cheapest route to go would be sell what you have and buy a 700/208 combo. Might even luck out and work a trade with somebody and get drivelines, Auto peddles and cross member.
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You don't have to swap in a column shift, you could just use a floor shifter. I'm not sure why you would want to swap the guages...unless your talking about the shift indicator thingy... /forums/images/graemlins/grin.gif
