I went mudding today...........o sh!t i F*cked it up!!!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NITRO, Apr 14, 2002.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    My second battery tipped over and all the acid leaked out making a hole in the ps hose. it ran out of fluid and i drove it home about 1 mile. is my ps pump destroyed or what?
    NITRO
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It might be. Replace the hose and put fluid in it. To bleed it, you'll have to jack the front tires off the ground and add fluid, crank the wheel back and forth, add some more fluid, crank the wheels some more, etc. If your pump still doesn't work or acts up, replace it. They're about $75 new, or you can find a used one anywhere really cheap.
  3. kilroy
    kilroy Registered Member
    Nov 25, 2001
    85
    Alaska, Anchorage area
    Maybe not. Replace the hose, fill it up and give it a try. The only thing you may loose is the cost of some fluid.
  4. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    it turns out the hose jusy had a small leak and we didnt notice until we tried to turn. then it was too late and we had to pull into long john silvers. but, i got it fixed and it worx ok now. so i guess i dont need a new pump. thanx for the replies.
    NITRO
