i woulld like info on 203 idea
Discussion in 'The Garage' started by sweetk30, Mar 14, 2007.
  1. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    i have a crew cab. so wb is not a problem for drivelines. i have a 32spline 400 203 range box . i would like to bolt it up to the tranny and have it just a range box with a fixed yoke output rear. then i would use a divorced 205 in the middle to run the tcase dutys. this is just a idea tho.
    is there a kit anyone makes or can this be made fairly reasonably price ranged for a custom job?
    thanks for any info.
  2. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    ummm, good idea, i'd like to see more info
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i don't think it would be that hard to build. youd have to have the stock np203 shaft resplined to 32 spline at the correct length with the correct threads on the end. you then need to make a plate for the back of the range box that holds a bearing. the shaft would need a shoulder for the bearing to ride on so when the yoke is tightened it will push on the bearing which will push on the shaft. the plate on the back will need a seal for the yoke.
    i think i could do it all on a lathe except the resplining of the shaft. i would definitely get it hardened after that though.
    i have an idea of a divorced doubler for my truck, i know of a ford divorced np203. probably get it really cheap also.
