ID-ing transmission and transfer case?
Discussion in 'The Garage' started by bettabruce, Feb 9, 2005.
  1. bettabruce
    bettabruce Registered Member
    Feb 7, 2005
    19
    Jackson, MS
    I own a 75 K5 and I was wondering how to identify
    the transmission and transfer case. Also, I don't know how
    to tell if my truck has full or part time 4wd. At the moment,
    my truck is crippled with 2wd. Thanks in advance.
  2. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    Are you Auto or manual? If your manual its a SM465... a muncie tranmission.
    Your transefer should either be a np205 part-time, or a np203 which is full time.
    Auto... should either be a TH400 or TH350 3spds. Quickest is the pan on the bottom, TH400 has a bigger more square shaped pan.
  3. check to see if there is a PTO cover IF there is, ita 205 part time
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I thought the TH350 was more square shaped? It is square except for the corner chopped off.
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the th350 tranny has a square pan with a corner cut off, the th400 has a illinois shapped pan and a 700r4 (not avaliable untill 82) has a square pan.
    a np203 and np205 both have pto covers. the np203 is long and has a 1" thick adapter. the np205 has atleast a 3" thick adapter (depending on auto or stick) and has a small cover with 3 bolts holding it on in the middle on rear of the tcase.
  6. eclipse
    Jan 1, 2005
    1,245
    Sparks, NV
    doh... your right I got that backwords, the TH350 is the squarepan with the notched corner :blush:
  7. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    if the tranny is stock
    Manual - Sm465 (Shift Pattern is L 1 2 3 R)
    Auto - TH350 (3 speed, square pan with 1 corner 45'ed)
    tcase is easiest to ID by shift pattern:
    Np203: (Full time - many have been converted to part time)
    Low Lock
    Low
    N
    High
    High Lock
    Np205: (Part time)
    4Lo
    4High
    N
    2High
    if its not stock, then it gets more complicated]
    As for fulltime/parttime, Do you have locking hubs on the front axle?
    Yes - Part time (could be np205 or converted np203)
    No - Full time (np203)
