id numbers on a 87 10bolt rear axle????
Discussion in 'The Garage' started by Supreme70, Aug 7, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    I wondering where I would find the I.D. numbers for ring gear identification, need to find out which gear I have now and replace, I know i can pull the rear cover off but the axle is junk and I just want the numbers, I also need to know what the numbers are for the gears.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    on axle tube right hand side towards front top part of axle tube when looking at front of axle with lit laying how it would be mounted under truck
    about 6" away from where tube goes into end of diff housing casting
    scrape/wire brush whole area til you come across three capitalized stamped in letters
    call local chevy dealer parts counter and tell them the three letters and the year make model of the truck
    they will tell you ratio and if posi or not
    this is another first thing i do with GM vehicles i get is check axle ratio
    good luck
