ID this NP205
Discussion in 'The Garage' started by garlicbreath, Jun 4, 2006.
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I might be picking this up from a buddy but was hoping someone on here could tell what tranny it had in front of it and if it is a round pattern or the other one, what is it called, a figure 8? I might be picking up a th400-203 combo from him, and I already have a th350-205 in my 71. both factory installed. If this 205 in the pic is a 32 spline input, whats a good price? Also, what should I pay for a used 400-203? Condition unknown and from hillbilliies so your guess is a good as mine. No offense to the hilly's, I just graduated from hillbilly status!:haha:
    I just noticed it has the slip shaft output. I already have a 205, could I swap my output into this one if this one is a 32 spline input?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    That is a figure 8 pattern 205 that came out from behind a TH350 27 spline. It is a later 205 as it has a rear slip yoke and not a fixed yoke.
  3. garlicbreath
    May 17, 2003
    1,136
    Denver
    I thought I read somewhere that the old cases were figure 8, and newer ones were round? But the slipjoint is of course a newer case.
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Def. a th350 27 spline 205. My guess would be an 80-81.
  5. goldwing2000
    goldwing2000 Guest
    To answer this question: Yes, the output housing assemblies are interchangable. Slap on a new gasket and yoke seal and you're good to go.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    80 and newer had the slip yoke. the round pattern started in 85. this is most likely from an 80 because it is the only year that you can get the slip yoke 205 behind a th350. in 81 the np208 were being used.
  7. K588
    K588 1/2 ton status Premium Member
    Feb 19, 2005
    332
    19
    Westminster,Maryland
    looks like an '80, bought one recently without the adaptor and paid $75 for it if that helps.
  8. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you can swap the outputs from any 205 to any 205...remove the 6 bolts that hold the entire yoke assembly on (no need to remove yoke) and pull it off. be caefull, there are needle bearings inside, they usulally dont fall out but i pack em with grease so they dont fall when reassembling...
