ID this sensor
Discussion in 'The Garage' started by mccomas, Jan 1, 2004.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    while looking for my oil pressure sending unit, i broke the lead off of this sensor. the tip of the sensor is broken and the sensor will have to be replaced. this is on the left side (driver's side) of my motor. it is just to the rear of the most forward spark plug and had a green wire on it. this pic was taken straight on with the spark plugs located from left to right. i need to know what is so that i can get a replacement. thanks...
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    That would be a coolant temperature sensor /forums/images/graemlins/thumb.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The tip of the sensor looks fine. The connector on that comes in from the side on a 90 degree angle. The sides of the connector fit over the end part of the connector. /forums/images/graemlins/cool.gif
  4. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    i thought that i broke a tip off of it. i will go back in the morning and see if i can slide the connector on from the side...
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Coolant temperature sensor...for the gauge only.
    The tip of that looks fine...it should look like the head of a nail.
