Idea for T case drop
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Sep 20, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I know I am going to have to drop my T case when I do my lift and was wondering if instead of just flipping the spacers why not make some spacers out of steel bar stock. I figured on using some 1"x1 1/2" and cut it the length of the crossmember and drilling holes through them for the bolts. I think it should help the stability of the t case and keep the frame from bending at the crossmember. Reason I am thinking about this is because a few weeks ago I was over at Rodgers and we pulled the trans and t case from a Blazer that had the spacers flipped and at each one the frame was bent up a little from the truck being pounded on pretty hard. Also I can go with like a 1"x1" and make some out of 1/4"x1" so the drop can be adjusted a 1/4" at a time till it is correct. What do you guys think of this idea?
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    just remember the more you drop the rear of the xfer case the higher the front one raises... and the froont is much shorter than the rear one...
  3. buzzk5
    buzzk5 Registered Member
    Aug 30, 2001
    29
    gimli,mb,ca
    when i found my k5 it was 77 auto/203 had a piece of 2inch square tube btween the frame
    and the crossmember 5 inch bolt thru frame/spacer/crsmember it worked fine....swapped
    a 4spd std and reused the spacer still worked fine...even the clutch mech worked fine...
    i've dumped it and reperched my D70 when i upgraded still works fine....
    jeeeps arnt real blazers ...
    jj........i think he was insane, so i forgived him lol
    Dave
    80K5 on ice
    are they all spinning?????
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I have a 2" in mine and I cant get it all the way to 1st gear unless I space down the shifter linkage at the pivot at the frame. I was gonna get some 1x2x1/4 box tube today before I put my tranny back in, and take out the spacer I put in the linkage for temp. Ive been told since I done this that 1 inch was the max you wanted to go. Now Im not so sure.
    I get all the exercise I need pushing my luck! [​IMG]
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Wayne, thats exactly how my old Brown Turd was done. It had 1/4" spacers stacked on each other until it was down to about 1 1/2".
    Each 'spacer' was a 1/4" x 1 1/2" x 6" long flat steel. Two holes drilled in each piece.
    IMO, this would be better than using the spacers under the crossmember now. Wont flex as much with the solid steel stock.
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  6. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
