Idea ...Torsion Bar Driveshaft - CAN IT BE DONE!?
Discussion in 'The Garage' started by BigBurban350, Aug 5, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Wouldnt a torsion bar driveshaft (properly fabbed and balanced) be very helpful; dampening shock saving trannys and be like a slingshot torsionally. It would build and release energy.
    Amybody ever do this?
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    but wouldn't that cause bad throttle response and take a lot of getting used to? Sitting on the rocks step on the gas and a second or two later it responds doesn't sound like my idea of a good thing. I know my K5's carb needs to be rebuilt and since its accelerator pump is messed up its not responsive at all and it was hard to get used to.
  3. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    give it a shot. what the hell if the write brothers (i'm sure i spelled it wrong) didn't try ?experiment. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I am sure the problem I mentioned could be overcome by just learning how it behaves. The only thing I can think is seeing as the rear shaft would most likely be longer than the front it would be different torsionally wouldn't it? Differnt front and rear torque on the tires then no? Or am I not thinking right?
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    sure, build and release torque..but then try to stop...the rear wheels will either overcome the brakes and snap the shaft...or you will just have some serious ass pounding going on when it bounces, binds up and breaks the tranny...
