Ideal exhaust setup.
Discussion in 'The Garage' started by riggz, Feb 15, 2005.
  1. riggz
    riggz Registered Member
    Feb 9, 2005
    85
    Roswell, GA
    Another thread got me thinking, what is the ideal exhaust setup to maximize horsepower out of an 87 350 TBI that will be pushing around 350-400hp. Not a DD so sound isnt an issue. What headers, cats, mufflers would you use? Money isn't a big issue, but I'm still looking for the best value.
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    THorley Tri-y's are great headers. I like my Hooker headers too, they seem to be fairly popular. I would be a single 3" exhaust with a good two chamber muffler would flow enough but I am partial to dual 2.5" pipe and dual mufflers.
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I am running a set of DynoMax Ceramic coated headers. Not the best. Ceramic coating is pretty much covered with md after 2 years and tarnished and have had problems with the bolts staying on the heads. Too thin of a mating surface. So No DYNOMAX. I do have true dual exhaust 2 1/4" with 40 Series Flowmasters and sounds really good when running right. Use to set off car alarms at idle. :D:D Not running any cats as well. Use to but the 210 and the 5 took care of that for me on a weekend trip.
  4. riggz
    Feb 9, 2005
    85
    Roswell, GA
    what about a crossover pipe (H-pipe or X-pipe)? worth it?
  5. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Hooker Super Comp headers, Hooker exhaust cut outs (for the mud bogs), Eastern Tru Performance Converter (if your going to leave the converter), MagnaFlow mufflers (straight through, not restrictive like Flowmaster), and a MagnaFlow Tru-X X pipe. That will be my setup when I have an engine worthy of the exhaust.
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    THose are great performance headers but the standard comps have thicker guage material for longer life.
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Worth it for low to mid range engine speed torque and they also reduce resonance.
    Ideal placement is to build the system w/o one and paint from the collectors back with cheap paint. Go out and work it hard. Put the x-over at the point where the paint stopped pealing off. Likely that won't be in an easy spot though.
  8. riggz
    Feb 9, 2005
    85
    Roswell, GA
    which model # magnaflow muffler has straight thru?
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I would not buy a aftermarket X or H pipe for a Chevy. They really dont do a whole lot for 350s. H/X pipes are more of a Ford Winsor motor thing. They work great and build good power on HO 5.0s and 351 W engines because of their fireing order.
    If you want one, do what ntsqd said about painting the exhaust and putting the crossover where the paint burns. Will add a bit more torque and I think it sounds better with a crossover( H )pipe. But not really needed on a 350 for performance. Regular Dual exhaust is best IMHO.
  10. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    All MagnaFlow mufflers (except for the XL series) are straight through.
  11. riggz
    Feb 9, 2005
    85
    Roswell, GA
    sorry if im a bit ignorant here but, whats the difference between the oval and round body style mufflers? any difference between the size of them? (ie. larger diameter muffler = quieter sound?)
    also, what about the exhaust manifold? should i mess with that or not? *ill be rebuilding the engine around the same time i redo the exhaust*
