Ideal Temp?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Sep 1, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I put a new 4row radiator infront of my 350ci a few months ago and ever since the temp guage hardly moves. I like the fact that its keeping my girl nice and cool, but Im concerned about the winter. I thought that the guages were meant for the needle to run in the middle but mine runs at about 1/8th of the guage. It gets real cold here in Montana and im thinking maybe I need a new thermostat? or do ya'll from the North think i'll be all right?
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    As I understand it, the ideal temp is whatever temp thermostat you have...ie a 180 degree thermostat would run at 180 degrees etc. If you have trouble this winter not getting the engine hot enough, try putting some cardboard in front of the radiator. Also running a factory clutch fan can help keep this warm. You could also use a hotter thermostat in the winter, but if the one you have works, keep it.
  3. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    I run a 180* thermostat in the summer and a 210* in the winter for snow trips. Sure it doesn't get quite so cold here but it should work about the same for you.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I run a 180' thermostat year round. I've never had an overcooling issue and in the winter it gets down to -30' Celcius(-22' Farenheit) for weeks at a time.
  5. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I have the same thing with mine - a 76 Cheyenne 350 with 4 core radiator, unless there's something wrong, it stays about 1/8th too. Thot there was something wrong with it for a while. But I had no problem with that last year in Utah (just with everything else). I wouldn't worry about it.
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I run a 192 degree 'stat and my gauge never goes over 1/4...I'm not sure I trust the guage that much but the motor never seems to get hot. I figure it's better to be a little on the cool side than running the ragged edge of over-heating.
    Rene
  7. dyeager535
    26,977
    The thermostat regulates heating AND cooling, so you have nothing to worry about. It will stay shut until it reaches the designated t-stat temp (which is 195 stock) or it will stay OPEN until it reaches 195. (in cases of "overheating)
    if its excessively cold, it will stay shut until the engine warms the coolant up enough, and then open. Theres a bit more to it than that, but the system is pretty reliable outside of REAL extremes.
