Ideal tire width on 15X10 w/ 4" backspacing?
Discussion in 'The Garage' started by Iron_Weasel, Apr 13, 2005.
  1. Iron_Weasel
    Iron_Weasel Registered Member
    Mar 29, 2005
    70
    New Mexico
    Going to be putting a 4" suspension lift on my 79 K10 and I'd like to know if there is an "ideal" width.
    I plan on running 33's unless I get a killer deal on some 35's and can't decide between 10.50 or 12.50.
    For instance, I'm considering BFG AT's which come in 33x10.50x15 and 33x12.50x15. Also in the running are Dunlop Radial Mud Rovers..but those only come in 12.50 width.
    Any insight as to which would be better and why?
  2. durantk5
    durantk5 Registered Member
    Mar 1, 2005
    50
    Greensboro, NC
    i have 33 12.50's BFG at's and they are good. the 10.50's would look too skinny.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Pick a tire and get a rim that works with your tires. Don't pick tires based on rims.
    A 10.5" tire on a 10" rim is going to look funny IMO. All the G-ghetto mexicans do that around here. They run 12" or 14" rims on 12.5" tires to get the balloon look.
    For a truck that sees offroad use that is not what you want.
    I run 8" rims on 12.5" tires. I like the look but for me it is about the function. 8" rims will help your tires stay on the beads when you are offroad.
    Harley
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    12.5 is the minimum width I would even think about running on a 10" wide rim. I think my 13.5" wide tires are a bit to narrow for my 15x10's.
  5. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    What tires are you running? I am running a 13.5" wide Irok on 15x8's and kinda wish I had 15x10's...too much crowning IMO, but thats with Irok's.
    __________________
    '77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
    http://www.krazyk5.com
    http://community.webshots.com/user/trcksr4me
    http://community.webshots.com/user/trcksr4me2
  6. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    wheres bothel at? im in tri-cities
  7. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I think it's on 405, south of Everett.
  8. coptezr
    Jan 13, 2005
    342
    all us washington guys should meet up some time an wheel :D
  9. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I'm running 36x12.5x15 TSL bias plys. They are marked 12.5 on the sidewalls but they are actually 13.5" wide if you look at the specs on the web site. I've seen guys run them on 8" wide rims and don't know that I want that...Just need to find some 9" wide rims (or 8" wide with weld on beadlocks)
  10. JIMMY76
    JIMMY76 1/2 ton status
    Dec 28, 2004
    209
    HAUGHTON,LA
    i had 35x12.50's on 10" wide rims it looked funny to me the side wall was flat no bow in it
    i put the 15/35/15 tsl's on them look much better and the tsl's actually say 15x10 rim recommended
  11. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    good rule of thumb is min. 2" bigger tire width vs rim width. so a 12.50 tire is the smallest you want to go on a 10" rim.
  12. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    i had 35-12.50 bf mallterains on 15x10 looks funny.now have 38.5-15 boggers on 16.5x8.25 not too bad.
  13. JIMMY76
    Dec 28, 2004
    209
    HAUGHTON,LA
    i ran 35 12.5 on a 8.5 wide rim for years never had any problem now i have a 15 on a 10" no problems yet and on the side of my tsl 15/35/15 it even says rim size 15x10
  14. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    did u read my post wrong?i said tire should be at least 2" wider. your first combo was 4"difference and the second was 5" :dunno:
  15. GruntHunter
    GruntHunter 1/2 ton status
    Apr 28, 2002
    145
    Florida (Space Coast)
  16. JIMMY76
    Dec 28, 2004
    209
    HAUGHTON,LA
    oops I did my bad
