Ideas for a shorter throw shifter
Discussion in 'The Garage' started by clubba68, Dec 3, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    I have a 1970 K5 with 465/205 setup and the throw on the shifter is like a mile long. Are there any short-throw kits made for it, or is there anything I can do to shorten the throw and make it a smoother transition from gear to gear? It is kind of stubborn right now in addition to being a mile long.
    -Andrew /forums/images/graemlins/usaflag.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I've searched for the same thing and came up empty so far. Hope your search is better than mine
  3. clubba68
    Dec 6, 2002
    1,511
    If it is I'll be the first to let you know. /forums/images/graemlins/thumb.gif
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Just cut the shaft and re-thread the end /forums/images/graemlins/thinking.gif
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    cutting the shifter wont make the throw any shorter...i hate that 1-2 shift in my 465, if im trying to bang gears it takes two or 3 tries, but shifting easy usually provides me with better smoother shifts..
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I took my shifter out and at the very bottom of it there is a little piece of steel that goes in, kinda t shaped, and is held in by a pin. It wobbled around alot and I had a spare shifter...so I experimented a little. I welded the little pin holes closed, and this did nothing, so I went right around the bottom of the shifter and welded the t piece solid to the rest of the shifter, then hit it w/ a grinder to smooth it up a little. Didn't make the throw any shorter, but it sure took alot of the slop out of the shifter and I haven't had any problems w/ it yet.
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Yes it will.
    Just for the sake of argument, let's say the shifter is 8 feet long, can you imagine how much you'd have to move the knob in order to shift gears. /forums/images/graemlins/eek.gif So yes, shortening the shifter will help out, but probably not enough to make it worth it.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes it will.
    Yup. Since the shifter is already 8 feet long...making it 6 feet long will only shorten the throws by 25%. /forums/images/graemlins/thumb.gif
    Solution for this? Unfortunately you'd have to go to an automatic.
