Ideas for Custom Overhead Console/Dome Light
Discussion in 'The Garage' started by 2Dogs, Dec 12, 2005.
  1. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Hey All,
    Looking to find cosole/dome light that will fit between overhead bars in my roll cage. The space is 5 inches - any of you found something cool that will work here? I am not worried about how it mounts, it just needs to be 5" wide or somethong I can trim to fit ;)
    Searching ebay at the moment, something like this but 5" wide and probably a bit shorter (most auctions do not list dimensions :doah:):
    http://cgi.ebay.com/ebaymotors/82-9...ewItemQQcategoryZ33695QQitemZ8020479763QQrdZ1
    Thanks.
  2. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    Maybe a stupid question, but do you still have a roof/headliner? I rigged up a new dome light from a semi trailer white LED. Cut a hole in the headliner for it and then ran sheet metal screws up into the roof to hold it. (It's actually a double roof up there, so you can do that without any leak problems, at least on my '86.) Turned out great. If you want, I can take some pictures...
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Dont' have a headliner - I am looking for some sort of light/console that I can fab into the middle tubes of the cage. It really requires a junkyard trip.....
    I am curious about your setup - please post up the pics.
  4. 5150_BEAST
    5150_BEAST Registered Member
    Oct 9, 2005
    62
    Los Angeles
    overhead console....
    i used one out of my friends old cherokee,it has dual map lights that i spliced to the factory dome wiring,it works great just trim the rear to fit it between the windshield and rear header where the cab and shell meet and a few self tappers into to roof and your set
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Get a pair of the HF rectangle foglight, when they go onsale. 8.00 a pair. Plenty of light inside.
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Of course you would look like a rolling indoor grow.:D I know that its heresy, but have you looked at any of the jeep aftermarket stuff?
  7. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I've been thinking something similar lately. cept I want all steel enclosure so I can mount Cb, stereo, plus lights inside and have the faces of both componants angled down slightly and toward the rear. still thinkin on it will post up when I get it designed!
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Hehe, thanks.
    I will be adding some bright light like a fog light for the rear. :p:
    The CB will be going in front of the dome light, in between the same 2 bars.
    I wish more of the ebay adds listed sizes - PITA to ask them all for measurements....
