Ideas for my off-frame build this winter
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Boondocks, May 19, 2005.
  1. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    I am planning a complete off-frame rebuild of my 72 K5 starting this winter.
    This rig will see only mild to moderate off-road conditions and is used primarily to tow trailers under 10K pounds and run the trails aound the area we hunt every year in central Idaho.
    Basically, I want to end up with a good looking, but functional vehicle for this usage.
    It already has a new GMPP 383HT and 3.73 gears on stock 16.5 x 10 wheels and suspension. A/C has been upgraded to VintageAir.
    My current thought is to seperate the body from the frame and completely strip the frame and do any fab, painting and re-assembly, while a body shop straightens and paints the body.
    Of course I plan to install some upgrades along the way and that is the point of the message. I would like some suggestions to accomplish the following:
    Upgrades:
    Seats, front and rear
    TH350 for a 4-speed auto and floor shifter
    TC 2 inch lift soft ride
    Brakes
    Wheels and tires
    Variable ratio steering box
    Steering column and wheel
    Gauges
    Additions:
    Roll cage
    Dual batteries
    Hidden winch ( I had an idea to mount it between the radiator and engine, as there is a lot of room there with the electric fans. )
    I plan to spend between 5k and 10k over the course of just under a year, to complete this.
    My task this summer to prepare for this endeavour is to setup a shop where I can work winter or summer, day or night. This will be a temporary structure.
    Also, to complete the planning and acquire whatever parts and material I will need at the start.
    So, given the above information, I am looking for ideas and suggestion to incorporate into this project.
    Thanks in advance for your time and insight.
