Ideas on a donor vehice ,I need a a fly wheel for a one piece main seal?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 72Blazerod, May 24, 2003.
  1. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    Hi guys,
    I am putting a 1990 Corvette L-98 (the entire engine, not just the TPI unit) into my 1972 Blazer. I want to run my original SM465 behind it, but I know that I need a flywheel that will mate to a one piece rear main seal on the Vette engine. What donor vehicles should I be scrounging in when I am at the junkyard? Just for your info, the Vette engine did come with its original starter and I have the original Blazer starter too. So, what years? What vehicles? How many teeth (considering I have both starters)?
  2. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    I would just get a flywheel from a 87 and up truck with a 305/350 motor. Should be the same tooth count as the early style as the newer starters fit the older trucks. I know this because I have a starter from a 92 on my 68...
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    just remember that 153 tooth wheels fit the straight across bolt hole starter noses and the 168 tooth wheels fit the staggered bolt hole starter noses
    86 was first year for one piece rear main seals, 86 and up is wheel you need to find,
