Ideas on rebuilding my 350?????
Discussion in 'The Garage' started by blazingjesse, Aug 23, 2002.
  1. blazingjesse
    blazingjesse 1/2 ton status
    Mar 13, 2001
    159
    kayenta, AZ
    I found a fellow in NM that would rebuild my 350, $1500 to bring up to a 400hp competition motor. $1100 if i bring him just the motor. What should i look out for, and any good ideas for the motor while it's torn apart? fuel economy is important, so keep that in mind. I like making it to the next gas station, if you know what i mean.
  2. JoseK5
    JoseK5 Registered Member
    Dec 12, 2001
    62
    Lebanon
    383 is the way to go. Shoot for 9.0:1 compression, and vortec heads. Lots of litterature about this, just run a search and you'll see the big picture. Good luck
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Well 400hp and mileage don't go hand in hand unfortunately. /forums/images/icons/frown.gif Keep it more mild, like 330 hp. You'll have more low-end grunt and better mileage with a tamer motor. Vortec heads, Edelbrock Performer intake, and one of the smaller 4x4 Xtreme cams from comp (or the like) and you'll have something you can live with.
    FYI, I run...
    '83 C15 Shortbox
    355 4-bolt main
    345np cast federal-mogul flat-tops
    vortec heads
    performer intake
    comp 4x4 Xtreme .447/.462 210/218 111 LSA
    Q-Jet
    SM 465 hooked to 3.08 rear
    With my foot in it alot and running the A/C, I've been getting 16-17 mpg. I then found I had the rotor button put in wrong in the distributor and the float way too high. So now I've got a lot more juice and a little leaner running carb. I bet I could hit the big 2-0 if I played my cards right. But, at least high teens for sure.
  4. blazingjesse
    Mar 13, 2001
    159
    kayenta, AZ
    ok But how much would it cost with vortec heads??? Need an answer ASAP!!!
  5. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Hmmm, 'bout $750 for the complete package. That would be with heads, intake, intake gaskets (special type needed), valve cover gaskets, and a set of junkyard valve covers. You'll also need self-aligning rocker arms. Lots of guys sell those on e-bay because they buy crate motors and swap them out right off the bat. Those centerbolt covers are superior to the old stlye ones too. That $700 would be offset by the fact that you wouldn't need a valve job, guide work, or having your heads milled flat again.
    If you have an old 350 in your possesion, I bet you could get it all done for $1,500. ARP bolts would be recommended for the rods (big ends of the rods have to be re-sized, no biggie), head bolts, and main bolts (not absolutely required)
