ideas?? to get tire to seat.
Discussion in 'The Garage' started by 74757685k5, Oct 3, 2005.
  1. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    I have 38.5x15x16.5 boggers i'm try'n to put on 12in wide wheels.the are the recomended width but,the tire shop cant get them to seat.they tryd a ''cheeta''.no luck.any ideas would be helpfull. thanx.
  2. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    Fill it with ether and put a match to it. I recomend not doing that but what ever works. :D :D
    I would let all the air back out, break what little bead has set and coat it with dish soap. Then air it back up and pound the piss out of it with a big hammer.
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I use a big 2 or 3" wide tie down ratchet strap. Wrap it around the tire and rachet it down until the side walls expand out. This may take 2 people one to apply pressure to the center of the tire (I have jumped on it) while the other one rachets it down.
  4. 74757685k5
    Nov 13, 2004
    258
    montana
    that sounds safer than the first reply . i'll try that .
  5. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    You do realise that I was joking about the ether right?
    The soap part is safe. The place that was trying to set them should have done that also before they even tried to mount the tire.
    And yeah. Rachet straps are good also.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
  7. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i mounted all 4 of my 38.5 boggers on the rims using starting fluid and a lighter. works awesome just dont singe your arm hair or your eyebrows!!!!! :wink1: :eek1: ;) :o
  8. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    ether works..
    We used starting fluid to seat the beads on the front end loader tires at the junkyard all the time!--it IS dangerous--but it was the only way we could do it too..ever try to squeeze a loader tire??--its like iron!--we'd just jack it up off the ground,spray in about a 5 second burst of starting fluid,clip the air hose from the compressor on and quickly toss a burning rag or newspaper at the tire and POP!!--or "BOOOOM" depending of the amount of ether,temarature,etc..once we blew a tire we'd plugged with a huge 1/1/4" industrial size tire plug/patch apart and ruined it--ether CAN and WILL explode violently at times if you use too much!..we learned after doing it a dozen times just how much it takes!--a little goes a long way! :eek1: :crazy:
    IF YOU TRY THIS BE VERY CAREFUL!!--(I'd always hide behind something sturdy while tossing the lit rag or newspaper!)... :crazy:
  9. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    yep the ether trick works. that's how they get those funky looking tires on low riders
  10. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    The ratchet strap is the way i would do this. I also leave the valve stem out while seating the bead so air flows in faster. I have more luck if i stand the tire up as if it were on a truck.
  11. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    The bomb (ether, lighter fluid, etc.) solution works well but it's really dangerous and best reserved for emergency situations or trail fixes. To seat my boggers I used a ratchet strap, a lot of soapy water, an air chuck clipped onto the valve stem, and a good deal of my 210 pounds.
  12. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    set them out in the sunlight all day. the heat will help soffen up the tires then stap them like listed and also blast them. and also stand them up and shove the short side of the rim up to the bead. then blast them from the long side of the rim. on the rim there is a short section before the drop and a long section. blasting from the long side helps the air stay in longer as it is a smaller gap for it to get out. i do big truck and mud tires alot. try this and good luck.
  13. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I have had luck taking the dismounted tire, blocking it "open" with blocks of wood between the beads. In your case 4 evenly spaced blocks of wood 14 inches long or so. Set the tire in a cool or better yet cold place. The tire will take a "set" overnite. One at a time mount them on the rim, strap them and put air to it. It helps to remove the valve core. I've done this a number of times in my garage. Last option is ether FAR from the house... good luck
  14. sweetk30
    Nov 1, 2004
    25,554
    548
    red brute where are you in sothertier ny?
  15. 74757685k5
    Nov 13, 2004
    258
    montana
  16. RedBrute
    Sep 22, 2002
    346
    Get on 17, head East, exit66. Apalachin...seems we aren't to far away from each other.
  17. RedBrute
    Sep 22, 2002
    346
    What technique worked for you? curious minds want to know. You aren't missing eyebrows are you?
  18. sweetk30
    Nov 1, 2004
    25,554
    548
  19. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    tire seater
    Just get a small air tank have a 2'' female plug weld in and a 2'' ballvalve and a air fitting and fill up the tank .Then BLAST that tire.
  20. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Thats how we get semi tires to seat at my buddys shop
