Identify this and its use please.
Discussion in 'The Garage' started by clarkjw24, Oct 2, 2005.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I found this hooked up in a 66 ford that I was parting. Is this a standard for ebrakes back then and would it work on my K5 with rear disk?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Its a line lock. Just a standard micro lock valve. Ill take it if you dont want it :D
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I think 85's got it, looks like a regular line lock to me, that's why it says operational braking only. If you don't want it, ship it my way, Mankato Minnesota is about 30 miles east of where I live. :D
  4. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    So can I pipe into the rear brakes and have an ebrake. I dont' want to get into the debate about linelocks and crap. Just is it worth having? BTW what do they usually cost?
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    As long as the valve is still functional you'll have a line lock, not really an e-brake :D
    I'm not sure if it's worth keeping around since it's fully mechanical and you'd have to either plumb your brake lines into the cab or put the switch under the hood. IMHO an electric one would be more convenient.
  6. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Would'nt you apply brake first then lift lever to lock the line pressure.
  7. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Yes, You have to apply brake pressure first to seat the shoes/pads then set the Micro lock to hold the brake pressure on them. All the Micro lock does is replace Your foot and brake pedal. But as with any hydraulic system there is bleed off. I use Micro locks every day at work and they are only a back up to the emergency brake. If I use them for a long period of time I will usually reset them about every 30 minutes.
  8. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    It's a Mico lock...not "micro lock" for God's sake. You look at it every day Corey.
    It'd be great for a trail e-brake, but definitely wasn't factory issue on a passenger car. See em on old forklift's a lot.
    Rene
  9. Corey 78K5
    13,055
    Humboldt County, CA
    I know, I just call them that and never think about it when I type it. OPPS
  10. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    I'm just bustin on ya Corey...:p: 99% of people i know call them "micro-locks".
    Rene
  11. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    No, just like it says on the valve, you lift the lever then apply the brakes. It has a check valve in it. It wouldn't hold right if you apply the brakes first.
  12. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
  13. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    The lines were unhooked when I got it but I assume you run it inline. Come out of the rear brake res, into the lever, back out the lever to the line that was feeding the rear brakes?
  14. sweetk30
    Nov 1, 2004
    25,539
    538
    yep and clic the link i posted for parts and stuff.
