Identify this axle!! UPDATE WHAT ARE THESE NUMBERS...
Discussion in 'The Garage' started by 84gmcjimmy, May 3, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, I'm slowly cleaning up the yard since my dad is gone... so I am keeping certain things, and selling others. I was wondering what kind of axle this is so I can find out if it is any use to me. Here are a few pics to help /forums/images/graemlins/thumb.gif
    There you go. I'm pretty sure it's out of a ford because of the shock mounts /forums/images/graemlins/dunno.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Re: Identify this axle!!
    It looks to be a semi float D60. /forums/images/graemlins/thumb.gif
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I concur Dana axle SF type looks like a 60 /forums/images/graemlins/waytogo.gif
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea looks like the axle i just picked up but mine is full floating (ford D60)
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yep a semi float 60, I always love, name that axle
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Is it worth keeping /forums/images/graemlins/confused.gif
  7. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    there are better axles out there. personally i have no desire to run a SF axle.
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I know there is better axles out there, but this is free, and would do for me until I can find a 14bff. This would hold up with 35" tires right? Should I or should I not? /forums/images/graemlins/dunno.gif
  9. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    How do u tell if its a full float or semi, i thought some one said if u could just pull the shaft with out hassle its a ff, is this true.. sorry to change subject. thanks
  10. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    FF's have a bigass hub sticking out....SF's don't... /forums/images/graemlins/grin.gif
  11. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Yes it should hold up with 35's no problem at all, I'd run it if I was on a budget and it was lying in my yard free, especially if it had the right gears. /forums/images/graemlins/thumb.gif
  12. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Yesterday, i pulled an axle outta a rear 60 all i had to do was take out 8 bolts and it came out so would that be ff? Thanks.
  13. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yes. /forums/images/graemlins/waytogo.gif
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    In another post someone said that axle was on the wrong side is this true? /forums/images/graemlins/confused.gif
    I have no clue what gears they are because like I said it was just in my back yard, If I were to pull the cover, how do I find out the gears? Thanks /forums/images/graemlins/thumb.gif
  15. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    A semi float axle has a c clip located inside the diff on the end of the axle shaft to secure the shaft from coming out. A full float axle has bolts securing the axle from the outside, you dont have to remove the diff cover to remove the axle shaft. /forums/images/graemlins/thumb.gif
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    we are looking at the bottom as far as I can tell. Its just sitting upside down, nothing to worry about. Someone was probably being stupid and thought its a front axle even though its clearly in the center.
  17. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Steve to check the gear ratio remove the diff cover, count the ring gear teeth and also the pinion gear teeth. Divide the numbers and you get your ratio....for example 41 teeth on the ring gear and 10 teeth on the pinion gear would be 4.10 /forums/images/graemlins/thumb.gif
  18. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    On the 60 i found, i pulled the cover and there were a series of numbers on the ring gear. That will probably tell you but i am not for sure.
  19. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    That seems simple enough... I hope /forums/images/graemlins/doah.gif
  20. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Heck, you can do this with one arm tied behind your back /forums/images/graemlins/rotfl.gif
