Identify this part and tell me what its for...
Discussion in 'The Garage' started by cbbr, Oct 18, 2006.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I stol this pic from buffblazer's thread. What is the bar attached to the top of the axle called (Panhard?) and does it act as a swaybar? Looks like the shocks are "inboarded" from the factory too?
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It is considered a panhard bar.
    It keeps the axle located from right to left,somewhat nessesary on a coil spring suspension like that.
  3. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    That is correct, a tracbar/panhardbar. Look at the suspension: trailing arms with coil springs. It only keeps the axle from going side to side. Like it does up front.
  4. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    I believe that some leaf spring suspension also use a panhard bar. I think that the Ferd trucks do. I think that it is added to eliminate the small amount of slop that occurs in a leaf sprung suspension. It tightens up the handling and makes the vehicle more responsive.
    As for sway control... I don't think it does much for sway control.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Road racers with rear leafs use panhard bars for lateral location when possible. Like a drag link, the longer they are the better they work.
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    F350 does from 86+. Because of the front shackle - and how narrow that shackle is, some extra lateral support is necessary.
  7. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    yup..
    I just welded one back on an 89 Jeep Wrangler a few days ago--it's bracket to the rear end rotted off and it broke away from the housing--had to re-weld and add more metal to secure it!..I was suprised to see one on a vehicle with leafs,especially something as light as a Heep!.
    --I bet it doesn't do much with leaf springs..not many vehicles need or use one with leaf springs..only reason I fixed it was because the guy selling it didn't want a potential buyer hearing it banging around under there!..(and I hope they don't look to close at my hacked attempts at frame repair either!:doah: )...
