Identify this steering box
Discussion in 'The Garage' started by MTMike, Apr 3, 2005.
  1. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Is this a 2wd or a 4wd box?
    My truck's vin is a C10, but I'm wondering if the PO put a 4x4 box in there or if he just moved the pitman arm on a 2wd box.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    That is definately a 4WD box. On the 2WD box the pitman arm is held on with a large nut on the bottom of the shaft and not a bolt through the pitman arm.
    Also on 2WD box's the pitman arm can be indexed 4 different ways but on the 4WD box the pitman arm will only go on one way.
  3. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Thanks, thats what I need to know. :waytogo:
  4. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Also a 2-WD boxes pitman arm has a ball joint (as opposed to a tapered hole, which a 4-WD box has) where the pitman arm connects to the drag link (unless the 2-WD box is being used on a cross-over system).
  5. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    the vin is most likly correct for the body. it was possible swaped to the 4x4 frame at one time.
