Identify
Discussion in 'Pacific Region' started by crawford, Apr 19, 2004.
  1. crawford
    crawford 1/2 ton status
    Feb 13, 2004
    229
    Vancouver, WA
    There is a valve or something in between the passenger side ramhorn and the exhaust pipe on my '72. It seems to have some sort of spring or weight mechanism on the outside and it's about an inch thick. Anyone know what this is and if it can be removed?
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Are you talking about the heat riser that's bolted in between the manifold and exhaust pipe? It has a little butterfly flap in it? You can disconnect it. I haven't had mine connected for years. If you take it out, you'll need some way to bolt the exhaust pipe back up. I suppose you could remove the flap, but then you'd need to weld the hole closed where the shoulder bolt goes through it or something. /forums/images/graemlins/thinking.gif You'd get a nasty popping noise out of it if you didn't. /forums/images/graemlins/doah.gif
    I was going to remove that whole thing too. Once I looked at it, I figured it wasn't worth the headache.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    A friend of mine just removed the butterfly and put set screws in the holes to plug it back up. Bolted everything back together after that. /forums/images/graemlins/thumb.gif
  4. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    ditto on that, did that when I put in a 400 in replacement of my stock 305 and was too lazy to change out my exhaust.
  5. crawford
    Feb 13, 2004
    229
    Vancouver, WA
    Cool, thanks. I'll probably just remove the flap.
  6. kennyw
    Jun 9, 2002
    13,224
    94
    If you do that, you will have to drill and tap some thread on one side but it is easy to do /forums/images/graemlins/thumb.gif
