Identifying 400 vs 350 in '79 Jimmy?
Discussion in 'The Garage' started by wy4tt, Feb 22, 2005.
  1. wy4tt
    wy4tt 1/2 ton status
    Feb 20, 2005
    153
    USA
    Is there a quick way to tell if a '79 has a 400 or 350? Or do I have to check the numbers? Thanks.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Best check the numbers....
    Second pull the inspection cover and look at the flexplate. Is there a weight welded onto it with drill marks in it for balance?
    Three freeze plugs = 400, although not all 400's have them....
  3. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    well I can give you a pic of a t-350 I had loaded
    if you want a good reference, go to your local performance shop and look at the tranny pans so you can learn the difference,
    or look on jet's website, they have some decent pics:grin:
  4. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    t-400 pan
  5. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    t-350 pan
  6. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,268
    159
    Wisconsin
    Are you talking about engines or transmissions?
    They mentioned stuff about both, I'll add some info about engines.
    - some 400s have 3 freeze plugs, some don't.
    - the engines that don't may or may not have a boss for a 3rd freeze plug that is not drilled.
    - it may have "509" casted in the middle where the freeze plug would be if there isn't any boss casted in
    - all 400s have a large round radius sticking out the side of the block on the #1 cylinder because the bore is larger, you can feel it with your hand
    - the balancer on a 400 has material removed around part of the outer edge because it it externally balanced from the factory.
    - if the heads are off 400s have 2 small steam holes between all of the cylinders that other SBCs don't have.
    Good luck man. :waytogo:
