Identifying Dana 60 gear ratios
Discussion in 'The Garage' started by ClassicCat, Apr 12, 2007.
  1. ClassicCat
    ClassicCat Newbie
    Apr 12, 2007
    Washington State
    First time user. How do you identify Dana 60 gear ratios? Where is the tag located? Thanks.
  2. tennyohpc
    tennyohpc 1/2 ton status
    Jan 30, 2007
    108
    ABQ,NM
    The factory tag should be bolted to the diff cover. however if there is no tag you can open the cover up and look on the ring gear(you may have to turn the gear to find it) there will be a number like 41 10 and that will identify the gears inside. i perfer this message as sometimes you can have a tag on a diff that has differant gears inside.
  3. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    Mine had a tag bolted to the diff, but I could see how that could be left off if someone took the cover off and forgot to put the tag back on.
