Identifying fluid leak in drum
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Panther, Mar 11, 2003.
  1. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    When I went out to work on the truck on Sat, I saw fluid running down the bottom of my rear, passenger side rim. So I pulled the rim and drum and there is fluid puddling in the drum and then running out. It is yellow so it has obviously mixed with water (which is understandable with the snow and mud) so I couldn't really ID it by look.
    I'm wondering how to figure out if it's the brake cylinder in the wheel or the axle seal leaking (which I believe could leak like that). The only thing that seems to be wet is the adjuster at the bottom. But it had sat for about a week. If it's the clyinder, it might explain the spongey brakes and pulling under hard braking. What can I do to test it?
    Thanks!!
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Wipe it as clean as you can then with the drum on pump the brakes a few times. Check for new fluid around the cylinder.
  3. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    On the wheel cylinder in the rear brakes, peel back the rubber dust boot on each side and inspect for brake fluid, if there is fluid behind these boots then its time to replace the leaky wheel cylinder. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's really easy to tell the difference. If it stinks like hell, then it's gear oil. /forums/images/graemlins/shocked.gif If it doesn't, then it's brake fluid. /forums/images/graemlins/thumb.gif
  5. Panther
    Aug 31, 2000
    845
    South Jersey
    Quick update: I found out something interesting last nite. I was reading the brakes chapter of my service manual and found out the red BRAKE light on the dash is a failure warning light in addition to being a parking brake light. I had ignored it thinking it was cause my parking brake was messed up (the PO didn't lengthen it after the lift). The light combined with apparent lack of hydraulic pressure in the rear brake I can feel in the brake pedal (which I now understand the cause of after reading the manual) and combined with the fact that the rubber boots on the cyliners are shot, means I will rebuild the two rear wheel cylinders. Then I'll regroup from there.
    All I can say is RTFM. /forums/images/graemlins/thumb.gif
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I prefer the taste test. If it's oily, terrible tasting and stinks, that's gear oil. If it instantly cleans your fingers and burns your tongue, that's brake fluid.
    You can also test by rubbing some of the fluid on the side of the vehicle. If the paint comes off, you know it's brake fluid.
  7. Panther
    Aug 31, 2000
    845
    South Jersey
    Yeah good idea. I'll try both. /forums/images/graemlins/tongue.gif
  8. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    If the bbots are torn up you might be better off w/ new wheel cyl's. IIRC, 2 new ones were about $15 more than 2 rebuild kits ~ $25 vs $10
  9. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    Good idea. I have done the paint one my self.
    Andrew
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  10. Panther
    Aug 31, 2000
    845
    South Jersey
    Good call Jim. I couldn't even get the rebuild kit from my local parts store. They were only $10 a piece for new cylinders. At that price, he doesn't even stock the rebuild kits.
