Identifying High Output Alternator
Discussion in 'The Garage' started by willymonster, Jan 7, 2007.
  1. willymonster
    willymonster 1/2 ton status
    Feb 18, 2006
    183
    PARADISE,CA
    does anybody know how to identify a high output alternator ? i was at picknpull today and saw alot of van/campers and was curious if they might have one but i dont know how to tell :confused:
  2. dyeager535
    26,980
    All the Delco alternators I've ever seen have the rated output stamped on the cover (around the circumference, not front or rear) along with some other stuff, like "Delco" IIRC, as well as part numbers.
    If it's been rebuilt, many times this info is ground off. :(
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Even if it has been rebuilt it could have been built to put out more amps.
  4. dyeager535
    26,980
    True. I'm mainly talking about stuff in the wrecking yard. Alternators bought from Autozone, Checker, Schucks, Kragen, Pep Boys Etc., will oftentimes be found in wrecking yard vehicles, so it's common to come across new looking alternators with no idea what they actually are output-wise.
    Good thing about many wrecking yard vehicles, if it isn't there for theft or accident, many times they will have little used replacement parts...since so many people spend money on replacing parts randomly to solve problems, the same vehicle they just wasted money on they end up giving to wrecking yards because they couldn't fix it. :)
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    How very true that is.
  6. willymonster
    Feb 18, 2006
    183
    PARADISE,CA
    how lucky for us :D
  7. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    Many years ago (shows how long since I replaced one) they used to grind off the GM stamped info; now of days I can't tell ya.
  8. willymonster
    Feb 18, 2006
    183
    PARADISE,CA
    oh ya so basicly the only way to tell if its high output is to take it apart ? i know they make those kits to convert and off the shelf ones but what to look for ? i dont have a clue :crazy:
  9. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You could try to find one off of a commercial type GM vehicle, I don't know the part number or even the official name, but I was told they are large case GM altenators. That is what I have, rated at 100 amps. I guess the bigger case is designed to help handle more heat so the internals won't burn running near full bore.
