IDing injectors - anyone know of a reference guide or website?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BurbinOR, Jan 20, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Have this set of injectors I just took out of my TPI motor.........put new 24lb Accel units in and want to know what I 'had'.............anyone know of a website that I can use the numbers cast into these to compare/identify what brand they are and confirm the lb/hr rating?
    Numbers at the top area - one side is 5235047
    other side is 0 28 015 0222
    Other miscellaneous numbers - 542 cast into the injector plug housing. 086 cast into the body up at the top They are all black in color.
    Thanks.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com/>BlazzinOR's Beast Buildup</a>
  2. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    Here's what I found. It appears the injectors are from a 1985 305ci TPI and the flow is about 19lbs/hr. Here are some interesting sites I found.
    http://iroc.fbody.com/injectors.html
    Hope this helps.
    Jordan
  3. BigJohnson
    Jan 22, 2001
    207
    AL
    And this one, it might not be anything new to you but I found it informative.
    <a target="_blank" href=http://chevythunder.com/index.htm>http://chevythunder.com/index.htm</a>
  4. BurbinOR
    5,829
    Oregon
    Absolutely what I needed. Thanks a million.
