ID'ing the 14 bolt detroit locker
Discussion in 'The Garage' started by atho, Oct 6, 2004.
  1. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    ID\'ing the 14 bolt detroit locker
    Is there an easy way to tell if a 14b has a detroit with the diff cover off? The axle is not in a truck. I am looking to buy a 14b DL to put in my Eaton and run 14b axleshafts. My Eaton has an OEM DL, and you can easily see it thru holes in the carrier. This 14 bolt carrier does not seem to have any, and I am largely unfamiliar with it, so pardon the stupid newb question.
    I will try to post pics of it, can anyone help?
  2. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    Re: ID\'ing the 14 bolt detroit locker
    links don't work
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    It looks like it could be a DL. It should have 4 cross pin holes, if it is. If it has 3 then it's a Gov-lock.
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Looks like a gov-lock to me /forums/images/graemlins/dunno.gif The carriers is how you can tell as mentioned above three crosspin holes=gov-lock 4 crosspin holes= Detroit.
    This pic the spacing looks to be 3 holes the side of it also looks like a GL carrier /forums/images/graemlins/frown.gif
  6. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Thanks for the input, at least I havent bought it yet, and 14 bolt lockers are cheap. Maybe I should try to trade my Eaton's for one /forums/images/graemlins/thinking.gif
  7. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    3 does equal gov-loc...4 equals open diff...OR POSSIBLY detroit...easiest way to tell for a detroit is spin the tires and listen to see if it makes a ratcheting sound...but that is deffinently a gov-loc /forums/images/graemlins/waytogo.gif
  8. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    When yall say sross pins holes are yall talking about those circles that are on the outside of the ring gear??
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Does the open carrier have any cross pins??
  10. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    open has 4 crosspins /forums/images/graemlins/thumb.gif u cnat really tell a detroit just by looking at it, cuz the detroit drops in, and replaces the spiders...and since 14bolts are sealed up, ya cant see the spiders...so one with a detroit will look like an open diff...only way to really tell is to spin one tire and listen for a ratcheting sound /forums/images/graemlins/thumb.gif
  11. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    It's hard to see from the pics...
    Do both axles lock-up???
    But...since the detroit replaces the spiders...
    I'd look for the spiders...thru the carrier access holes..
    If you see a spring...that's probably a detroit..
    Also...a detroit creates back-lash...almost a 1/4 turn...
    when turning the pinion...
  12. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'll second that. The diff in that pic is definately a Gov-Loc. /forums/images/graemlins/deal.gif
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    I second what Jerry(JK5) said. Look at the carrier and see if the opening are there for the spiders. If you see spider gears, it's open, if the holes are there but you see something other than gears, DL. If there are no openings, its more than likely a Gov-Loc and I think the pic you posted is a gov-loc...
  14. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I agree with JK5 too, if you can see a spring in there that tightens up when the axle locks its most definetely a OEM Detroit.. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  15. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Thats what I was wondering...on my Eaton axle, I can see the Detroit through the carrier...there are no holes in this one except for the crosspin holes.
  16. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    A picture is worth 1000 words. By the way, you should check out Tom's Catalog. Everything from R&P's to Shock Mounts.
    Gov-Loc
    Open Carrier and Detroit Locker
  17. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    It's a gov-lock. /forums/images/graemlins/deal.gif
    Open carrier
    Gov-lock carrier
  18. Emmettology 101
    May 9, 2000
    8,126
    FL
    Has anyone ever broke a gov-lok in a 14ff?
  19. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    Gov-Lock is probably the most frequently replaced part in GM rear axles.
    Here is a pic of my open-carrier/Detroit locker set up...
    Hopefully these pics might help a little bit /forums/images/graemlins/thumb.gif
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not that I know of...but a Gov-lok doesn't work that well, either.
