Idiot light for 4WD - where's it supposed to be?
Discussion in 'The Garage' started by AuH2O, Jan 6, 2007.
  1. AuH2O
    AuH2O 1/2 ton status
    Oct 4, 2006
    185
    FL
    On the right side of my K5 steering column, opposite the service engine soon light, there's a red indicator light that I figured was for 4WD, but nothing's hooked up to it behind the dash. Instead, when I shift to 4WD a gauge-light type wedge-socket bulb dangling freely behind & below the gauge cluster lights up. Don't ask me why (but if anyone has an explanation I'm all ears). I just wanted to check with you guys if the red indicator light is indeed meant for 4WD - the manual makes no mention of it that I know - and if so I'll just reroute the wires from the other bulb and remove that one.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    The 4wd indicator is on the left gauge, is it the MPH?? I haven't owned in years?? I'd say if it lights up when you put it in 4wd, then its for the indicator....
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It is supposed to be on the Printed Circuit on the gague pod, to illuminate the Tell-Tale indicator, as you mention.
    It is a negative switched circuit to illuminate the bulb. Meaning, the gauge pod already has 12v+ to the light socket from the gauge power circuit, and when you shift into 4wd, the little switch in the transfercase completes the path to ground, illuminating the tell-tale.
    Why it would be separated out in it's own light socket seperate from the gauge pod itself, is pretty weird. I've never seen that.
  4. Dogman12
    Dogman12 1/2 ton status
    Nov 12, 2006
    111
    Easthamptom Ma. 01027
    I have an 85 Jimmy i bought a couple a months ago and it was doing the exact thing, just take the gauge cluster out and put the socket back in. If you undo the speedo cable from under the truck and put some slack in the cable you wont have to unhook the cable from the gauge cluster. should be a 20 min fix.
  5. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    You could just reach up behind dash and reinstall light. Only hard ones to get this way is blinkers. Also both 77 and 83 I have seen 4wd light on wires.
    oops edit :83 not 87
  6. dyeager535
    26,975
    Early 4WD indicator light wiring was separate of the instrument panel lighting. I would guess roughly 1981+ the indicator light wiring was integral with the panel.
    I only know for certain that a 1980 I pulled the harness from was set up separate, and that the mid-1980's clusters I have are not separate, nor is my 1991 cluster.
  7. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Hey i have an 88 blazer and wen i put my truck in 4WD no light comes on and i know that its sopposed to cas wen i took apart my gauge cluster i put a new bulb in the 4wd indicator light buit still noting? any input?
  8. dyeager535
    26,975
    I'd suspect either the switch on the t-case or the wiring more than anything else.
    PCB could be bad for that bulb as well. If the later switches are the same as described above, pulling the connector from the t-case and checking for a path to ground from the one wire, with 12V on the other, will prove the wiring TO the switch is good.
    The switch itself can be tested for continuity between the two terminals while shifting in/out of 4WD. From my experience the switches tend to get very picky on what movement turns them off/on. So you might not get continuity when shifting to 4WD, which means the switch is probably no good.
  9. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    My 83 truck has that little light dangleing to, ive just never got around to slippin it back in, it doesnt really bother me, I know when its in 4x, Ill prolly do it sometime soon now seein as the truck is on the workbench right now
  10. AuH2O
    Oct 4, 2006
    185
    FL
    Alright, so then that bulb dangling behind the dash is indeed the proper 4WD lamp. Then I just have to reinstall it and fasten it properly - no biggie since I have most of it taken apart right now anyway. :D
    But then I wonder what that red bulb to the right of the column is... It's got its own hole in the dash and everything, but as I said, nothing's hooked up to it. I could snap a pic of it next time I'm in the garage if anyone wants to see it.
  11. Dogman12
    Nov 12, 2006
    111
    Mine has a choke light.
    Jesse
  12. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    mine has a choke and a 4wd light but my 4wd light doesnt work. i didnt know there was one untill i took the gauges apart
  13. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    My cluster has the integrated 4wd light and I just wanted to know what colors the wires are leading from the dash to the switch?
    I think they might be white/black but not sure.
  14. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    here ya go..
    according to my Clymer books wiring diagram,the 4wd light uses a grey wire,and at the switch on the transfer case there is a black and a white wire the black wire goes to one side of the bulb,the grey one goes to the other side of the bulb and comes from the fuse box....this is a 1982 diagram I'm looking at....:crazy:
  15. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Thanks! :waytogo:
    I knew there were a black and white wire involved somehow.
