Idiots guide to adjusting your hood!!!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ak7, May 2, 2002.
  1. ak7
    ak7 Registered Member
    Feb 15, 2002
    57
    Hayward, CA
    Allright now...
    I feel completely stupid for having to ask this. My hood closes just fine in the front but everytime I have to walk to each side of the truck to push down the rear of the hood. Is there an adjustment I can make or some type of new bracket or spring to correct this?
    Ak7
  2. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    I think that means that the hinge is binding. Just try to lubricate it real good.
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    Out of curiousity, has anyone replaced the springs with a set of lift shocks (they look like mini shock absorbers)? Just leaving the hinge as is and remove the spring and mount the lift shocks in place. I know that Thumper did this to his 2nd gen Blazer but wondering if it would work on a 1st gen also seeing that the hood is heavier than a 2nd gen.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I am running without any springs and it's kinda scary some times.when i get a good gust of wind the hood lifts up and seems it's gonna fly out. I hope it don't.
    ARQ.
  5. BAD4WD
    BAD4WD Registered Member
    Feb 4, 2002
    63
    Sonora
    Your hinges are worn out, I went down to the gm dealer 2 years ago & paid 120.00 for new hinges & springs. My hood closes flush & opens all the way, automatically when I release the latch. later,,,,,
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    My hood does the same thing.
    I have to push down at the back of it after i close it, and then on big bumps the back part of the hood will come back up again.
    I've heared that it's just the springs that are worn out.
    I bought new springs from LMC for something like $8 a piece i think. I just have to figure out how to get them in now. /forums/images/icons/smile.gif
