Idle Adjust on 84K5?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Nov 3, 2000.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    What is the step by step on doing this on a stock carburator?
  2. UseYourBlinker
    Jun 7, 2000
    11,117
    Thanks for the help! It's going in the shop....
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It's really simple..........on the bottom driver's side of the carb there is a small set screw that applies more or less pressure on the idle arm- in for higher idle, out for lower idle. I don't have a tach, so I just go by ear for to adjust for the proper idle.
  4. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    If your having idle problems and the idle screw doesn't do anything you are probably going to have to adjust your
    TPS(throtle position sensor) or possibly you MC(mixture control) sonenoid. To do these you need a volt meter and a dwell meter. I've been through this many times on my
    84 TransAm. Are you getting any codes?
    Topless73
