Idle is much higher now.. thoughts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bnc04, Feb 19, 2004.
  1. bnc04
    bnc04 Guest
    Hi, Recently for no reason, the idle on my 88 tbi 350 went from a steady 900-1k to 1500-1600. It's been pretty chilly around here of late so I have not done alot of work to find the culprit. I did take some starter spray and it will stumble and almost dies while spraying around the TBI to intake gasket so I presume this is the cause,, anything else I should look for or do when I get the weather and time to replace the gasket?
    Thanks in advance,
    Brett
  2. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    TBIS are famous for leaking at the base--->intake gasket.
