Idle Issues/EGR valve
Discussion in 'The Garage' started by elwhitey, Mar 26, 2006.
  1. elwhitey
    elwhitey Registered Member
    Mar 21, 2005
    42
    Chandler, Az.
    I celebrated PHX's new found rain a couple of weeks back and now my '74 Jimmy has been wanting to stall once it gets out of the garage. I have tightened down the carb, changed the PCV, air filter, plug wires, and have now gotten to the EGR valve. I have not been able to find any diagrams showing where the vaccum line goes to on it. Does it just hang out? My experience tells me no but I am not seeing anything to indicate otherwise. I gootta trip to Mexico hinging on this.
  2. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    The vac. line from the EGR does go some where. I believe it goes to the intake or carb. You have a vac leak, that is why it stalls.
    One way to find it, go get a can of carb cleaner and spray it around the base of the carb, etc. The rpms will change. That is where the vac leak is.
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Look at the around the base of the carb for a vacuum hose fitting that doesn't have a hose on it (which would be a gargantuan vacuum leak); this is likely where the EGR valve's vac hose hooks up. I'm trying to think if a '74 would have one of those little diagrams underhood, showing where all the vacuum lines go.
  4. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    early or later 350?
    The older 350's had the EGR valve vacuum hose connected to a ported vacuum switch located in the thermostat outlet,so it wont activate the EGR valve until the engine is warmed up..the vacuum source for this switch usually came from a port on the carb itself, some had letters cast into the carb near the port to identify the various things they connected to ( A,B,C,D,etc..)..I think the EGR used the "D" port,or it may even have "EGR" on it..its a ported vacuum source,not manifold vaccuum..:crazy:
